2G Butterfly Intake Cleaning
Kai Hefner
Freelancer
481
282
Jun 21, 2018
Calgary, AB, Canada
Hey!
I finally got around to trying to clean up the butterfly stock intake that’s been sitting around. There is some gunk inside, and I want to freshen up the outside.
I’m worried about normal foaming agents or anything just incase they damage the valve things in the intake. I also guess that it probably can’t be hot tanked without coming apart (which I’m not the biggest fan on doing just yet).
What’s the best way to clean this?
I took mine apart and used degreaser and a bottle brush. I don't recommend taking the valves out, as they're a major pain to reassemble correctly.
I made new gaskets out of gasket paper when I reassembled it. Mine worked great for the past several years, but I recently switched back to a ported stock intake manifold for packaging reasons. Made accessing anything on the back of the engine a PITA.
It also pulled a ton of vacuum and even with my catch cans (they're not perfect) it pulled alot of oil through the pcv line. I intend to improve my cans in the near future.
Not appreciable porting IMO. Maybe extrude honing the plenum, maybe the runners. It's designed for low end tq, and it does that but I don't feel that it will flow well up top past standard bolt on turbos.
I'd just clean it up and use it, great for the street.
