Buschar Racing / Aeromotice FPR setup
DeathBeast
177
Mar 29, 2002
Bay Area, California
I have the buschar racing FPR, and I haven't been able to change the fuel pressure.
*I tried spinning the screw at idle, and the pressure stays at 20.
*I've also tried this:
-"Use the fuelpump check terminal next to the battery to pressurize the system and make sure you have no leaks. All you have to do it get a wire with alligator clips, attach it to the fuelpump check terminal and the positive battery post, and it will power up the pump"
-Nothing happened.
-Does the car have to be off to change the Fuel Pressure?
-What am I doing wrong?
~I'm sure there's no leaks... and FPR is on right... I'm spinng the full screw, not just the locking nut.
Thanx,
DeathBeast
