building boost
whitetsi95
100
Dec 17, 2007
Yuma, Arizona
I have a question. Why does my boost build faster when I am in a higher gear? Like when I'm in first or second gear second, and running about 1500-200 rpms, then slam on the gas it takes longer to build up boost. But when im running about 1500-200 rpms in 4th gear then slam on the gas my boost builds up alot faster. Just wondering why it does that?
I've actually experienced the exact opposite since it takes less time to get the rpms up to the boost threshold in lower gears. You will reach the same psi at a slightly lower rpm in a higher gear since it has more time to spool the turbo.
Load also has an effect on spool. In higher gears there will be more engine load, leading to a quicker spool. I'm not sure if there is a limit to this though.
If you are a turbocharger, pushing against the pistons with air, "boost" is how hard you have to push against them. It's the same as you pushing your kid sister in her wagon versus pushing a loaded city bus up a hill. Less load, less boost.
If the either is moving ten miles an hour, you'd have to run like hell to build any "boost" against them.
