bbarnumboy
- 52
- 1
- Feb 20, 2012
Everett,
Washington
I have dsmlink V2 and i am trying to hookup my Innovate wideband for data logging. I hooked it up on my 1g through pin 15, being the exhaust temp sensor.
My wideband is running just fine with the gauge, but i cannot get it to show anything on the live dsmlink datalog. I assume i need a buffer circuit.
My question is this
Since i have the sensor and gauge already hooked up, can i just forget about the + and - wires that go to the sensor shown on the left of the picture below?
I already have power to the sensor and gauge, so can I just power the buffer from the ecu and hook my 0-5V line through the circuit now? In the end using all 3 wires on the right of the picture and the center wire on the left of the picture?
Since i used the exhaust gas temp pin, in the dsmlinks settings do I use the exhaust Gas Solenoid option to log? That is what i have it setup for currently and i am getting zero voltage readout.
It sucks i am still stuck to this newbie section. Oh well, such is life. Hopefully someone with knowledge can see this thread. Seems to be little info in regards to the actual wiring of this buffer. On top of that which pins do i get my power and ground from on the ecu?
Also since i will be wiring my own buffer up, i have a question. the bottom picture of this picture is the diagram for wiring this buffer. The outlined chip is the one i am using. Where pin 6 joins pin 2 before it goes out to pin#15 on the ecu, is that done in the chip our do i just splice the 6 pin of the chip into the wire coming from pin2 on the chip?
I found the answer finally. thank. this is my answer. Please let me know if this is an incorrect answer.
My question is this
Right the WB power and ground are not connected to the buffer there totally separate. There is then a white wire coming from the 4 pin connection on the back of the UEGO, this white wire is the analog signal output. You connect it to the gray middle input wire on the buffer, and the yellow signal output to the EGRtemp input. Which I did, I then connected the 5V+ wire to pin 23 and the ground to pin 24. The other two wires on the input side go unused. There only used in a paticuler instance that does not apply to this application.
