BSEK install.
TsiTalon90
159
Dec 23, 2002
Granby, Massachusetts
I'm in the middle of installing a bunch of things, my first question is i removed all my belts before i did this, now i got the balance shaft sprocket off but the oil sprocket just spins, does anyone have tips on how to hold it still to loosen it? Also I'm installing the SBR FMIC, what did u guys use to cut threw the radiator holes with? Am i going to need a slimline?
Thanks :dsm: :talon: :laser:
You can try a strap wrench. I made mine out of a piece of seatbelt material and a 1/2 square pipe. Or you can drop the oil pan and put a wrench on the shaft.
