BSE Question.
Davids97Eclipse
54
Apr 4, 2011
Aurora, Colorado
Hello, i spun my rear balnce shaft bearing
Do i need to install the rear bearing to block off oil gallary if i'm using the stubby shaft?
Some threads say the rear bearing is not needed with stubby shaft?
Just double checkin Thanks, Dave
You spun the oil pump BS bearing?
No you will not need that bearing, no oil port to block off there, it is/was lubed from the BS.
The better question is, Why did you spin that bearing...
