xveganxcowboyx
- 1,525
- 23
- May 15, 2005
St. Paul,
Minnesota
Today one of my turbo coolant lines sprung a leak. I picked up a new hose (turns out to be a bit too big grrrr...) Anyway, when I went to remove the piece of hose I snapped apart the plastic piece right below the radiator cap. It's the piece with 2 outlets that the throttle body tubes run into. It broke right where the tubes run out of it (so it is now a main shaft and the 2 offshoots stuck in the rubber hoses)
Questions: What exactly does this system do? How essential is it? (IE will it run temporarily without it?) Is there an easy fix or a place to order the part?
Can take a picture if it is needed.
THANKS!
THANKS!
Not really, as long as you keep the cat on you're all good.
