4gfun
Supporting VIP
- 2,012
- 56
- Dec 10, 2007
Ask Me,
Virginia
The middle fuel injector bolt snapped flush when I was tightening it. I did not overtighten it at all. The injector seals did not fit the head correctly and caused tension on the bolts.
I tried an easy out but the drill bit broke off inside. I have also ended up drilling holes on the side of the broken bolt unfortunately. I tried to slot the remainder of the bolt so that I could use a flat head screwdriver but that didn't work.
How much drilling around there can I do before I mess the head up? Any ideas. I have soaked the bolt in Kroil etc but to no avail. I obviously can't use a torch around it
I have a built head that I'd like to throw on there and this gives me an excuse but even that is a bit extreme.
No local shop has left hand drill bits and I am not sure that even that will work. I am also concerned about getting too aggressive and messing up the space between the rail and the head.
Any ideas?
Thanks
.I have a built head that I'd like to throw on there and this gives me an excuse but even that is a bit extreme.
Any ideas?
Thanks
