Broken fins, no shaft play????
eagetal96
39
Nov 7, 2004
grand forks, North Dakota
Hello, i just have a few questions. I recently began having problems with the T25, the car will boost to about 8 psi and then fall on its face. Looking at the the turbo i notice that a few of the fins are chiped pretty good but it seems like there isn't much shaft play at all? I just purchased another T25 and it almost seems like there is more shaft play in this one than my old one. No fins are chipped though. Will a few chips make that much of a difference or does my problem lye elsewhere????
Sounds like your turbo ate something for lunch which in turn broke the fins. A turbo is just like a fan, a very powerful fan and if the blades are broken or chipped its effeciency goes downhill to be able to blow air. Get it :cool:
The chips will affect the efficiency of the turbo, but if it isnt badly out of balance it might not be your problem. It almost sounds like you have a boost leak. I'd definitly check that out first. You can search and find out how or go to www.vfaq.com and find out how to do it.
I would also suggest that you resell that T25 and look into getting a 14b turbo from a 1g dsm. They are MUCH better than the t25.
Good luck :thumb:
