Broken C Clip on wastegate Arm
Swish
125
Sep 14, 2009
Savannah, Georgia
Ok so was I was changing my wastegate and while trying to put the C Clip back on i managed to snap the rusty POS into 2 pieces.. well due to my bad luck i swear no auto parts store has C-clips only E-clips(no pun intended) so i got them instead.
Will these work ..
and just to be clear im talking about the the clip that holds the wastegate actuator arm onto the lever, that opens and closes the wastegate..
even though that thing says c clip that is a dang e clip
but that is where mine needs to go.. so i guess if they use them i could try them as well?
below is a C-Clip
He's saying weld the arm on to lever permanently. Which is all good unless your wastegate acuator fails and you need to take it off.
yea i figured that, I'm not doing that
If it holds it on and won't come off should work just fine bro.
YEAP it did!! after much pushing and forcing with some needle nose!
seems to hold even tighter
