Hurleyatticus4
- 43
- 0
- Oct 10, 2005
Schaumburg,
Illinois
So friday I swapped the ported small 16g for my 14b. I went to streets (huge meeting spot) [content removed]
Well, the next day I drained my coolant and put in the new stuff. And I was driving around and I noticed that when I would open the car up and get around 6500 rpms, that the car would like, cut off and jolt forward (knock of some sort?). I figured it was because I'm still using my stock 450cc injectors and I'm running really lean.
So I went back to the race area that night and [content removed] I launched from about 5000rpms. Next thing I know before I shift into second there is a big clunk/clink sound and the car feels like something is dragging under it and I couldnt put it into gear. I immediately though "Great, blew the tranny again 2 weeks after I redid it." But when I pulled over to the side of the road, nothing was dragging under the car, and all my coolant was leaking. Smoke was billowing from the hood obviously. But I really don't know what is wrong with the car.
We pushed it into a lot nearby, and it was making a clicking sound while we pushed it. I'm pretty sure all of the coolant is out of the car so I am afraid to start it right now. While it's sitting I can go through the shift patterns and everything seems fine. So what could be the problem?
My friend is coming over to look at it after school, but I thought I would ask some of you here who are more experienced.
Water pump? Old faulty hose maybe? Why does it feel like something is dragging under the car? Did I blow something?
Please let me know if you have any words of wisdom. Thanks guys.
-Alex
-Alex
, LMK, Im available all day long. I hate to see a broken Talon in my area. It could be a couple of things. It wouldnt go into gear when the car was on???? Did the motor die when you heard the clunk noise?? Oh, and that cut off and jolt was from you hitting fuel cut off, you maxed out your stock injectors, what psi boost are you running??
