Breaking up above 6k
Nos~4G63
340
Jun 2, 2002
Davie, Florida
I put some AV gas in my car last night and attempted to up the boost. I was having some breaking up in the past and Im not sure what it's from. I had the boost at 24psi and zero knock with about 22degrees timing and as soon as I hit 6k rpm the car feels like it is blowing the spark out. I checked the plugs and they look fine (bpr7's gapped at .028). I tried adding and subtractin fuel at 6k and it still does the same thing. The car has only been doing this for about 2 to 3 weeks now. It keeps revving past 6 but it still breaks up. What could it be? I am running the stock downpipe but no other exhaust, could it be from the backpressure?
ENGINE:
stock throttlebody
magnus intake
ported head with 5angle valve job
crower valvesprings
stock cams
arp head studs
cometic gasket
wiseco 8.5-1 86mm pistons
eagle rods
align honed
bored 1mmover
arp rod bolts
arp main studs
IGNITION:
magnecore wires
ngk bpr7es plugs
stock coils
FUEL:
255 hp walblow
aem rail
aeromotive regulator at 40psi
FIC 850cc injectors
ELECTRONICS/GAUGES:
SAFC
MAF translator
air/fuel gauge
palmV w/ pocketlogger
Keydiver chip w/ stage3 mods
INDUCTION:
4'' K&N
Forced performance cast intake pipe
FP3065
28''x10''x3'' front mount w/ 2.5'' piping
tial BOV
EXHAUST:
ported 2g exhaust manifold
2.5'' 02housing
tial 40mm dumped to atm.
stock downpipe
Stock coils have gone 9's. I think it may be too much timing for pump gas. I was getting 22degrees and I did some tuning with 18degress the car doesnt break up at all and with 20degrees it breaks up a little bit but not as bad.
I am currenty running 32 psi on my 3065 setup I had something similar to what you described at 18psi but it would work through it if you held on it. It turned out to be a couple of small boost leaks.
Yea, I am having the same problem ever since I swaped to my 60-1. It sputters up after 6k rpms. I can datalog and my rpms are actualy hoppin up and down about 200 rpms incremenets. but it does it worse in third not bad in first or second. Anybody else having this problem that found out what it was and could postit would help. I've been driving like this for over a month.
