Brand new 6bolts in Chi
Get Mitsu Caps, You usually can find it on google. They give the part # for the short blocks.
Don't quote me on all of this,
Here are a few "Important short blocks part #'s.
Non Turbo 6 Bolt: MD136420 ( Should have the 9 to 1 pistons)
Turbo 6 Bolt: MD136421 (7.8 to 1)
Non Turbo 1G 7 Bolt: MD192470 ( also 9 to 1)
Turbo 1G 7 Bolt: MD192471 (7.8 to 1)
These blocks will look almost identical from the outside. The 7 bolt is not casted the same as the 2G 7 bolts, so they will not fit right ( They will need like a 6 bolt swap, - Water pump, and oil pump mostly)
2G Short Blocks
Early 2G Turbo 7 Bolt : MD314497 ( early like 95 only w/ good oil squirters and flange bearings)
2G Turbo 7 bolt : MD330756 (later with the press style, and possibly flange or thrust - seems like I have seen both)
Hope this helps with the ebay sale, those look nice.
Jon
DSM Graveyard Inc.
I am pretty sure that mitsubishi part number is for a NON TURBO MODEL!
just fyi, no oil squirters and a 9:1 compression ratio.
