2G brakes rotors squeak
eclips3_xs
79
Jul 23, 2008
Burbank, Illinois
yeh hi i got this problem when i am braking my braking and is about to stop the brakes squeak grind kinda i replaced all the rotors and pads though. maybe needs lube or something.
Anti-squeal springs? I don't recall any springs in the 2g brakes.
edit - gah it's been so long it took me a while before I remembered to what he was referring.
^+1 Yes make sure you have the correct anti-squeel springs and shims on the pads. Also make sure the caliper rides back and forth smoothly on the pins (grease the pins inside the boot).
Use brake caliper grease. It's made to keep a slick condition with high heat unlike anti-seize or other type of lubricants.
