FuelInjected
- 130
- 1
- Aug 27, 2007
Newmarket,
hi guys, i am waiting on a set of slotted rotors and hps pads right now, should be here anytime within this or next week. my brakes started squeeking two days ago, everytime i brake, they squeak noticably. you think its ok if i drive another week or so? my brakes feel fine, just squeek?
2nd question on installation of rotors and pads:
it will be my first brake job, and i read through the manual a few times.
when i open the fluid reservoir, i'll syphon some fluid out, and then i replace rotors, and pads, and follow the rest of the procedure. after i am done, am i suppose to put some fluid back in, before i go and pump the pedal slowly...?
i just want to install brake rotors and pads without bleeding.
also if there is any manuals online with pics, would highly help, i tried looking around these forums, and on google, and only found pad installations, not rotors. unless i am blind.
Thanks guys!
Thanks guys!
