Brake rotor questions
killab443
602
3
Nov 24, 2003
Howell, New Jersey
I have a 92 fwd turbo with the 3000gt front brake upgrade. I found a full kit on line for rotors, pads and lines for 92-94 awd dsms(bigger front brakes). My question is will the rotors and pad fit on my dsm? Since I already have the front brake upgrade...Will the front rotors work? How about the rear?
I think we need some more info here about what kit you are talking about. If we don't know what kit your talking about we can't help.
I found a kit that has 4 brembo rotors for an awd 92-94(awds had bigger front brakes this year). Will these rear awd rotors fit on my 92 fwd in the rear? Will Theses front rotors fit on my factory upgraded brakes in the front? I have the 3000gt brakes on the front and I want to buy a kit that includes rotors pads and lines. Its a guy on this forum selling it alls it says is rotors pads and lines for 92-94 awd, no link is required
Your questions are still confusining as hell. You refer to factory upgraded brakes and then you say you have 3000gt brakes. Which is it?
im using 3000gt sl calipers I took them off of a junkyard car. I basically wanna know if 92 awd rear brakes are the same as 92 fwd rear brakes. Meaning same rotors and pads. I also want to know if 3000gt SL front brakes (dual piston)are the same as 92-94 awd front brakes. And if they also use the same rotors and pads. i know its confusing but I cant think of any other way to word it
