brake pedal drops when car is running
mattsGSTeclipse
204
8
Dec 20, 2005
Lewiston, Maine
After replacing all for calipers and the brake booster on my 2g GST. The brake pedal drops to the floor when the car is running. I bleed the master cylinder and the brake calipers in the correct order, right rear, left rear, right front, left front. The pedal is stiff when the car isn't running, but once I start it and press the brake the pedal drops to the floor. What should I check next?
I would have changed the brake master cylinder first,basically if the calipers show no signs of leaking then they are ok.As for the master cylinder weak piston seals can cause failure without any signs of leaking.
If you are sure it's bled right, and you are not losing fluid, it can only be the master cylinder. All else being correct I assume. Sometimes, it's real difficult to get all the air out. But if you have a pedal and are losing the pedal occasionally, I would look back to the master cylinder for sure. The booster would only give you a hard pedal if it was bad. You might just for grins and chuckles look at the point where the master cylinder goes on to the booster. At least just make sure.
Good Luck
Was there signs of fluid on / in the old booster? Why did you replace the booster? I ask caust the new booster may have an internal vacuum leak and be "suckin" the fluid out of the master into the booster housing.....
For what its worth...
Daryl
