Brake overhaul.
Blackrose
41
Aug 3, 2010
Highland, Indiana
Ok here is the thing. MY GST need new front calipers. I figure I may as well upgrade it all while Im in there. Dont want to go to crazy but I know the GSX has 2 pot Cals. Ive done some reading and I know that they will fit the GST without a problem. My question is, if im going to go with stainless brake lines do I but the ones for the GSX or the GST or does it even matter?
And yes I know I have to use the GSX rotors also...
If you are going to upgrade the brakes might as well do it right once and for all! Make sure the calipers come with the brackets for the brake pads first and foremost cause they are impossible to find! next step would be to get yourself a nice set of brake pads! And last but not least a good set of rotors will be key!
check out the powerslot big brake kit!
It's a nice 2 piece rotor design and its 12.5 inches over the stock 10.83! check them out here:
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Power Slot Plus Big Brake Kit : Mitsubishi Eclipse 95-99 AWD (Front Pair)
good luck!
