brake noise caliper
mystic_DSM
Apr 12, 2007
goodyear, Arizona
i was noticing this nosie coming from my front left wheel the faster i went the faster the noise would go i have allready replaced my pads and rotors so i new that could not be it so i took my brake caliper off and found out that that very top of my rotor (not the top where the pads touch but the part of the rotor tha has the spaces in it) was cutting into my caliper. everything is tight so i do not know why my caliper is resting on my rotor like that any answers?
Sounds to me like you either have the wrong rotors or wrong caliper. IIRC, I do believe the 2g gsx and gst have different calipers and rotors and pads. is there a possiblity that you have the gst calipers with gsx rotors? Seeing as though the GSX rotors would be bigger, they would rub on the GST calipers.
Did you match the new rotors to the old ones before you put them on? same with the pads?
Did the noise start before or after you did the brake work?
