BRAKE LIGHT always on !!
Twinturbo2800
288
Nov 7, 2004
Montgomeryville, Pennsylvania
wtf ? is thier a reason my brake light goes on and off all the time...... rubbing? should i get it checked out ?
its really pissin me off.
Did you check the switch? When you press the pedal down, you should hear a click. When you release it, it should click again. Check that first.
Also check the switch from the emergency brake/ hand brake.
Make sure it is in the right range or might be stuck.
OK i have had this problem in the past....if you have a manual then this might help. Check your brake pads. If possible, change them. I had a 95 Talon ESi and the brake light stayed on. I thought it was the censor for my e-brake but it was actually telling me that my brake pads are shot. Once i changed those, light went off.
that might be it eff... i have an auto but i can hear the skreech from that cricket thing on the break pads..... i guess ill order some green pads or somthing =)
ah damn, didint think that would throw it off.... LOL i think i was low, thnx!
all brake fluids the same right? pepboys run :)
thnx guys, fluid was the problem =) im such a newb
now if i can only figure out why my check engine light is on
