Brake calipers question
buhay6
1,661
65
Jul 9, 2010
Delisle, SK, Canada
Just a quick basic question that I cant seem to find the answer to. Are the single piston brake calipers between the n/t fwd and AWD interchange able
I'm building a 92 tsi AWD out of a 92 n/t gs and I'm missing virtually the whole brake system on the AWD shell.
Yes the front single piston calipers are interchangeable from 90-99. All of the 1g's use a brake hose that is threaded into the caliper and the 2g's use a banjo bolt, but they will all interchange with each other regardless of what they came from.
wow you've had your dsm since 92??!! live'n the dream man so jealous of you. The reason I'm not going duel piston calipers are because the single's are all I have access to right now, but when the local crusher finally gets more AWD's in stock then I'll pickup a full set.
Thanks for your input. :)
