BR 580 Track Results
Yes, but you won't need the EGR spacer. BTW I broke the shaft on mine last night at the track. This was my second one. I need to put a throttle stop on the pedal. I will probablly get the Holley this time.
Making a pedal stop is pretty much required when you use one of the ford TBs. Everyone I talk to that ran any brand TB without a stop broke the shaft eventually.
BTW BBKs seem to break more often than other brands FWIW.
Hey this just hit me:thumb:
Ever see a cable mounted adjustable stop?
It clamps to the cable via allen screws and when retracted fully contacts the sleeve?
That might work and be simple.
Yeah I had a BBK the first time and Eldebrock the second time. They are actually the same except for the writing. I have a friend who is selling me an Accufab which has a billet shaft. I shoudn't have to worry about it breaking but I'm still going to use a stop.
how does the car idle without the isc, is there something else on the ford TB that keeps it idling?
He has FAST. Just wire it to the ford ISC. FAST is more likely to be seen on a mustang anyway so it can be easily configured to operate a ford ISC.
No IAC motor here. The car idles just fine once you get it adjusted. Cold start is a pain to get right though.
