BOV leaking or normal?
96greengst
33
Nov 1, 2008
psl, Florida
my car has a turbo xs BOV the old owner put on,but the setscrews and nuts are striped on one of the 3 sides,and it will spin 90* is this normal for it to do so?
or is it leaking? and if its not normal can someone tell me what flange it looks like i have so i can get a diffrent BOV..
my boost spikes high then goes back to wheir i got the MBC set 15,16 psi.
and since the screw got stripped the bov seems louder? but it also moved a lil bit when i first got the car as well,LOL so im confused!
please watch this,small video of what im talking about,LOL
RIGHT CLICK SAVE AS:
http://www.plastikhosting.net/autoindex.php?dir=n20saturn/&file=bov_004.AVI
LOL the more i think about it,it must be alright cause i doubt those tiny screws and nuts would hold up against any decent amount of boost,the other ones that are on the peice of the BOV are tight. THOUGHTS>?
It isn't like the BOV is some special secret design. You can get dozens of cheap, generic BOV's that work just as well as an expensive one. If it's leaking, or broken, just replace it, fix it, w/e.
There should be an oring inside the connection to make the seal.
Have you made a boost leak checker to see if it's leaking? A little soapy water spraying on the joint while it's pressurized will tell you if it's leaking or not.
naw i havent made a leak checker yet,any recomendations on a BOV thats decent priced and will reuse that flange thats on there?
Just searched, and no, there is no other BOV you can use other than a turbo xs BOV. Even if you go with a different one, they are known to have a 50% chance of leaking out of the box. I would go with the 1G BOV and have the flange for it welded in.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
