bov hooked up right?
Status
Not open for further replies.
NeXtLeVeL
51
Apr 24, 2002
ojai,
how do i know my bov is hooked up right? its vented to the atmoshpere, the vaccum source from the intake mani is ran to the top nipple of my greddy type s. i dont hear it at all when i drive. i dont have a boost gauge controller or gauge so i dont know if i am boosting. the valve does not open up either. should i mess with the hard or soft setting? any help would be great.
It could be your spring, but mostly, they come set about right from the factory. You should be able to tell if you are boosting because you should either be able to hear the turbo or you can look at the generic gauge in the dash and see if it goes up and down when you floor it.
why are you venting to the atmosphere again?
well...its at negative boost when idleing, but i havent looked at it to see if it raises when i drive it. in neutral, it will raise, but wont make it past negative boost. if the bov is vented, when i look into the bov, shouldnt the valve open up after i let off the throttle? should i mess with the hard and soft setting?
i vented it because i didnt have an intake or hard pipe. its ghetto rigged.haha. so i juss plugged the hole and left it vented. i alseo wanted to be cool and have my bov be louder.
Status
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
