- Thread starter
- #26
ZSPTurbo
- 178
- 0
- Oct 30, 2002
Originally posted by larryd
just be careful with the nitrous. Your falling into the land of oz where everyone thinks strapping on 100 shot of nitrous is no big deal. Its easy to install, its easy to use, its also easy to blow your engine into itty bitty pieces.. Read up in the nitrous forum thoroughly before you attempt to run nitrous for your own good![]()
remember, I said exactly:
Originally posted by ZSPTurbo
I didnt say that its easy, i.e. strap it on and theres 100 more hp,
I said basically what u just told me,
.oh, and ladies and gentlemen, I present with you MY TOTALLY REVISED PLAN, with questions afterwards:
Power 1:
Downpipe - 175
QTP exhaust cutout - 170
Intake - 150 (get 3 inch, and silicon coupler reducer so it fits stock turbo)
Port the hell out of my O2 housing
Cost:
Power 2:
AEM EMS - 1200
GM Boost Control Solenoid (GMPartsDirect.com) - 10
2g knock sensor
Gagues
EGT Gague
A/F Gague
Boost Gague
Fuel Pressure Gague
Walbro 255 lph Fuel Pump - 100
Adjustable Fuel Pressure Regulator
Cost:
Power 3:
ADFX FMIC - 925
Some Gagues should go here... which ones?
Cost:
Cool Shtuff:
custom fiberglass fender flares / pulled fenders
17x9 wheels (buddy club P1 Racing, 17 lbs)
steering wheel - 200
shift knob - 50
Pedals - 50
custom vented hood
Cost:
Power 4:
Nitrous Express Stage One EFI Single Nozzle Kit - 775
Injectors - 450
Cost: 1225
Tranny:
Sent off to TRE for:
4 spider center diff
Shift rails
Steel shift forks
Double synchro 2nd
TRE spec 1st and 2nd gears
Oil magnet
Clutch (which one?)
Cost: 1700
Power 5:
T3/T4, 50 trim stage 3, .48 housing - 550
TiAL 35mm wastegate, .8 bar spring - 200
Wastegate dumptube - 50
Exhaust Manifold - 400
O2 housing - 250
Extras - 200
Cost: 1400
Power 6:
HKS 272 Cams-570
Crower Retainers and valve springs - 250
Crower Valves - 270
Crower adjustable cam sprockets - 165
Pistons (95+/Evo/JE/Ross)
Cost:
Whenever!
rewelded shifter (to make it short throw)
Clutch
Sway bars
Strut bars
Coilovers
Sheetmetal Intake Manifold
How much?
Gagues
harness
Maby?
Crower rods - 700
now here are my questions-
where should I put the nitrous? I would like to do it before the tranny, but Im not sure what would be best... between 1 and 2 or between step 2 and the cool shtuff?
my other question is-
what gagues do I need ONLY for tuning? whatever those gagues are, I can get rid of the actual gague, just get the sensor, and display the gague on my laptop during tuning.
my final question-
I have heard about converting to an MAP sensor.... what all is involved in that, and how much will I benefit from it? where would it go best in my order?
