Boostleak test shows boost coming out of the oil dump tube B16g
newTSIguy
471
Dec 14, 2008
Monroe, Washington
I did A boost turbo leak test on my 2g starting from the turbo inlet. I found pressure coming from my oil cap, so I pulled the oil dump tube and applied air again, just to find air rushing out of the oil dump tube. Are my seals shot? time for a rebuild? if so where should I buy a quality rebuild kit? thanks in advance.
Ken
Leaking through the PCV valve most likely, you can buy a 1 way check valve and install it to keep boost from entering through it.
