racinmasonc
- 45
- 1
- Oct 10, 2005
Rochester,
Minnesota
Hey guys.. this is what is happening.. MBC set at 17psi on the evo3 16g with the 7cm housing... the psi goes up to 17psi and holds for maybe 2000rpm, from 5000 - 7000.. the full 17psi isn't hitting when it should. this is what i'm thinking it could be:
My upper IC piping is very flexible (stock) you think by that when it sucks in the airflow drops dramatically? then under boost it'll eventually expand??
there is a hairline crack in the exhaust manifold, it might be all the way through, i don't know for sure... could that be the cause of it??? its hitting full boost in 2nd gear at actually 5500 rpms..
