boost variations
eoseitz
148
Jun 16, 2008
Marion, Ohio
I installed my boost controller last night. It doesn't seem to be working correctly though. When I hit the gas the car will go to around 6 lbs of boost in 1st gear, then 10 lbs in 2nd and 3rd, and finally 15 lbs in fourth. I assumed it should be at 15 lbs in first-fifth gear. Am I wrong about this?
It is varying because of the load on the engine.. From what you are telling me i can tell you using a MBC.. The only real way to prevent this from happening is either using an electronic boost controller such as a greddy profec or up the boost.. the higher the boost the less variance you'll see:thumb:
