Boost Question...low/high PSI
AnDYy187
108
Nov 4, 2004
Sterling Heights, Michigan
Okay....How much PSI am i supposto be pushing stock? Also... I'm pushin around 15 psi in 3rd gear...problem? normal? thanks.
[Edit: It starts off lower...like under 10, then i think if i can remeber correctly a little higher for 2nd and then 3rd is like 14-16 range]
I had this question because I heard around 15 is MAX so it was pretty much pointless for me to get a mbc... :confused:
So what do I do when i install my MBC? just stick it there and leave it? Cuz 15 is max correct?
