Boost not stopping with Blitz Electronic Boost Controller.
Cody D
93
May 26, 2004
Olds, AB, Canada
I know I have a small boost leak, but my setup worked fine for a long time even with the boost leak (on the intake manifold gasket I believe).
Is there a way to tell whether it is the boost leak, boost creep or whether it is my boost controller?
It just started a couple weeks ago.
I've done the vac line removal on Taboo's website.
I found this while searching...
http://dsmtuners.com/forums/showthread.php?t=158694&highlight=boost+creep
See the reason I don't think it is boost creep is because it goes up fast, real fast.
Would the boost leak do it?
I'm sure that the hoses to and from the boost controller are connected correctly. Because I did not change them from when it was working properly.
I bypassed the boost controller and ran straight off of my wastegate for boost control and it still went up, so it's either boost creep or boost leak.
That should be easier to fix than a new boost controller.
