THE REAL DEAL
- 462
- 2
- Jul 12, 2005
Evansville,
Indiana
I've been trying to find out the source of this problem for a few months now. When I first got the car, it would hold boost at 12 psi. A friend and I spent a day doing some of the free mods and when we took out the air filter, we removed the BCS but we put everything back the way it was. Took the car out for a spin and it ended up spiking to like 22 psi. We took it back to the garage and hooked his MBC up in my car to see if we could get it turned down. It kept doing the same thing.
Eventually we decided to port out the turbine housing, o2 housing, wastegate port, and the exhaust manifold to see if that would help. It did help some but it still spiked to about 15 psi in 2nd gear. 3rd and 4th were holding at 12. I left it that way for a couple weeks and now all of a sudden its holding at 18 psi in all gears, getting fuel cut obviously. So last week my friend and I got together again to check if I had boost leaks (because i can't build anymore that 1-2 psi when brake torquing) and to see if we could get the boost down. Well, I have 2 leaks that were obvious. One from those O rings in the TB and another around the SMIC. I'm not sure if the leaks would contribute to this or not. After that, we removed the BCS and hooked a vacuum line straight from the wastegate to the nipple on the intercooler pipe. From what my friend tells me, doing that will keep it at the stock boost setting. It still maxes out at 18 psi. If there's any information I'm missing that may help, let me know. Thanks.
Knew it was somethiing with that actuator,
