boost leak question.
HaveSomeJoe
66
Jun 3, 2007
Portland, Maine
I've been doing a boost leak test and I had a couple big ones that made my car buck and sputter. (one of them was at the inlet for the smic, there was aluminum corrosion that caused a bunch of little holes all the way around, JBWELD!) I fixed em up and I have another one that I'm wondering if anyone knows what it might be.
It sounds like its actually coming from the turbo, and the pressure gauge holds no psi (but it only holds a minimum of 20 pounds anyway) Are there any common leaks from the 14b? Or in that general area? (It MIGHT have been from the actual boost leak tester but I highly doubt it, it was clamped down pretty well.)
