husterka
- 43
- 0
- Apr 19, 2002
Sunman_IN
I am giving my 99 eclipse GSX a good tuneup before I begin to spend money on mods for it. I have changed the plugs, wires, timing belt, and PCV valve. I have also checked / changed all filters. Is there anything that I missed??? Also, I want to perform a boost leak test and I need to know exactly how to do this. I have made the intake adapter and have tried testing the system. I am using a bicycle pump to pressurize the system and as soon as I stop pumping, I can hear air escaping somewhere near the throttle body (side farthest from the IC pipe). I had read somewhere that you need to block off your EGR valve and also bring your engine to TDC in order to properly do this test or else the pressure will simply leak through the engine and out to the exhaust. Is this true???
If anyone has a fully detailed method for performing this test (preferably on a 2G) please post it here. Thanks!!!
