boost leak issues
brian102
142
Nov 6, 2010
coldwater, Michigan
http://i110.photobucket.com/albums/n106/brian102/IMAG0685.jpg
http://i110.photobucket.com/albums/n106/brian102/IMAG0686.jpg
So i built a boost leak tester last night and found many leaks. First one i came acros was a little rubber vac line laying underneath intake connected to nothing. It had yellow stipes down the side of it and only place i could find it to fit was on the end of one of the solenoids on firewall. The far left one in pic. Is that correct? Also another one was coming out of the bov. The car came with two different ones. Whats the difference between the two in the picture? Thank you
What psi are you running and are you checking for leaks at your desired psi? Is your valve leaking at the desired psi? If so upgrade.
the one on the car is the stock one and its known to leak and be crappy being plastic and all and the other just LOOKS like a 1g but its not. the flange is a circle and the whole thing just looks weird. i wouldnt recommend any of them
