Boost leak and still make psi
Slappster
1,046
Jun 20, 2002
Flower Mound, Texas
My 16g has a 8psi spring in the wastegate so thats all it'll boost. However my ic pipes look like they would leak, where the turbo and ic meet. If I make 8psi does that mean its not leaking at all or is it possible it still leaks but can still make the restricted boost.:confused:
how do they "look" like they would leak? it is possible tht they would leak or something over 8 psi or something...i dunno tho. and why is that wastegate set at 8 psi?
aww man put an MBC in :thumb: ill be doing that in about 2 days [ in the middle of my install but bent a water line :rolleyes: :mad: ]
as far as boost leak goes i made 15 psi on the t2small with a huge leak where the UICP met the intercooler.. so i dunno about that.
as far as the J pipe goes mine is kinda slanted too [ slow boy racing install kit ] i'm going to use some RTV to try and cure that
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
