Boost gauge reading high
akdov823
255
31
Sep 20, 2014
feeding hills, Massachusetts
So I'm pretty sure this is a vacuum line issue..I teed the vacuum line to the omni 4 bar map sensor with my innovate map sensor for the gauge. Also my omni map sensor is about a foot away from the Im vacuum source. I'm running a big e3 and it's reading about 33gm/sec but the boost is reading around 28 lbs. Clearly one of these is way off. Running 12 degrees of timing on 93 with no knock so I'm assuming I don't have the world's best 16g
