boost gauge installed
Status
Not open for further replies.
WOW!!!!!!!!!!!!!!!!!!!
That's the first time I heard that an EGT Gauge is worthless.
Just by curiosity, did some one tell you that, or that's what you think????
I understand that there not 100% accurate, but better safe than sorry.
When I'm at the track running 22psi of boost, and don't have an EGT gauge to tell me how hot the car is running, I would be worried.
I said "close to worthless".
I've come to that conclusion through personal experience as well as conversations with fellow DSM'ers.
When I'm at the track running 27psi of boost I don't have time to watch an EGT gauge eventually tell me approximately how hot the inside of the manifold might be.
turboedoutlaser, i have the same problem. everything seemed to read right, but that sound wasnt too assuring. so i took everything out and put some teflon tape around the adapter, and its a little quiter...not quit enough, ill do it again, maybe tonight. good luck
does anyone have any other ideas on what gauge to install along with the boost and a/f gauge?
I like the suggestions so far and the pros and cons for the different gauges. Thanks for the help.
Status
