Boost controller not working
Kheldar
152
Jun 30, 2003
Newport, Arkansas
ok
i tried to hook my controller up and i hooked it up noth ways cuz i dont really know in and out on it
this is the one i have
any help? i get 10psi no matter where the screw is set and then it creeps to 16
Here is a pic of the inlet and outlet for you.
Inlet goes to the T you have to make in the vacuum line between the intake manifold and blow off valve. Outlet goes to the nipple on the wastegate actuator.
If you check those things and still have problems, it could be that your actuator spring is very light (10psi of pressure opens the wastegate without being pushed open). You might should pull the cotter pin on the wastegate and try pulling it by hand, see how much force it takes.
well i had the same turbo and controller on my 1990 car and it worked and i had it turned up to 16 for a while
Well, then:
A) You have a boost leak
B) You have a exhaust leak
C) Your turbo is on it's way out
Take your pick... It can only be one of those if you know the turbo WAS good, and that the connections are all right.
well looking at it it spools later than b4 my car is smoking alot white mostly what are the signs of a turbo that is going out?
People would post a little more if you'd bother to do what we've already suggested. Have you bothered with a leak test yet? The smoke could be indicative of leaky turbo bearings, leaky valve seals, or a leaky headgasket for starters.
well i was referring more to what the signs of turbos going out because i dont have a leak tester and i did tighten the clamps on my ic pipes and none were really loose
newport is close to jonesboro and batesville or go north east from LR and when the interstate ends ur in newport
i am Shinsetsu on arimport dont know of anyother dsmer in my town
oh i found out what was wrong with mine the ball and spring are missing
i got a joe p and it works great
