Boost control HELP PLEASE
srGS-t
51
Jul 12, 2005
Hueytown, Alabama
ok this is a dumb ? but is there a way to lower your boost with out a MBC. THANKS
I dont think so, I could be wrong, but Ive never heard of a way, nor anyone asking to lower their stock boost, can I ask why??
WTF Your stock actuator should be set lower. On a 1G it is around 9PSI or something like that. If you set up the vacuum as if you had a MBC and just put the stock controller in backwards, it will use the actuator as your controller. Your the first person I have ever had inquire about lower the boost. Your nuts!!WTF :p :tease:
bmason said:
probly for better gas mileage i kinda wanna do it i get like 150 iles per a tank
Your either a Speed Racer, or you car has some major issues.WTF
Yes, just run a line directly from the pressure source to the wastegate actuator, thereby bypassing the stock boost control solenoid completely.
well for yalls info I am maxing out my stock injectors soo i need to lower the boost
