Boost Build Up But No Power
The_one
117
Oct 30, 2005
denver, Colorado
Hi DSM Tuners,
I have a problem related to boost and power output that i need some assitances with. Whenever, i drive My 95 AWD TSI i can hear, feel, and see the boost is building up by the Turbo (small 16g). But for some odd reasons the engine can not obtain that boost from the turbo. I drove my brother stock 97 gst and i could feel his car has more power output than mine. His turbo build up boost faster than mine too :confused:
Things i did/checked:
1. Boost Leak Test (Leaks Fixed with Silicon RTV)
2. Compression Test (Good, 130psi on all 4 cylinders)
3.
If anyone knows how to diagnose this problem. Feel free to post
Thank You Very Much
Vu
kenamond said:
Good info MyBeatGSX. I'll have to search around for high altitude compression numbers (I'm at 7500ft).
I found out something quite useful today w.r.t. boost leak testing. Doing the test on a warm motor makes a HUGE difference. I was leaking 1psi/second out the VC breather due to blow by and/or valve stem seal leaks on a cold motor, but I got 1psi per 5 seconds on a fully warmed up motor. Good to know when you think you got all the leaks but get too much coming out the VC breather.
Here is a link that related to doing compression test at high altitude
http://home.comcast.net/~saramasters/performance.htm
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
