Bolt size help!! Lower trans mount
portum89
65
9
Dec 7, 2011
Maple Grove, Minnesota
Hey guys, i hope someone can help me out. I am trying to find out what bolt size do i need for the lower transmission mount on my 2g gst. The metal mount has 2 holes that mount to the trans and it sits on the lower metal bar (cross member?) I can't seem to find the right bolt size. Somehow they came off and the mount is now rattling. The mount is right underneath my turbo basically. Thanks!
if it is the front engine mount to crossmember, they are MU242010 BOLT, ENG SUPPORT ROD, WASHER ASSEMBLED M10X30
Here is an example of it...basically yes the lower front motor mount. Except it looks like it mounts to the transmission case, not the block.
I believe you are right, m10x30 and yes it is the front motor mount on the cross memeber im missing the bolts that mount onto the block or tranny...looks to me that it is the tranny not the block.
ok i see it, looks like it does mount to the trans, washer assembled, m12x30 or m12x28, not sure why there are two options on that.
MF241309 (12x30) and MF241308 (12x28), both washer assembled
they are the same as the rear mount bolts too, so you can take one of those out and measure the length to find out which one you have.
