bolt question on turbo install
Endz0r
323
Oct 3, 2002
Cannon AFB, New Mexico
i'm going to a agp rs49 and as yall know, it's better to go from the oil filter housing, and they are not watercooled. anyways, i need to know the dimensions of the banjo bolt that goes from the head to the turbo (oil blockoff) and i need to know the bolt dimensions of the line that goes from the water pipe to the turbo (water blockoff). either that or i need to find a way to cut the pipe and route a peice of hose from the coolant supply to the coolant return.
thanks for the help homies!
slowboy carries both pieces for a couple bux that plug both of those
i'm not going to wait 7 days. my car has already been down for the last two weeks :-/
For the water block off in the block, I used the existing banjo bolt and 4-5 crush washers that I had. I think I did the same thing for the oil port coming from the head also.
For one (I think it was the water into the turbo) I took the existing pipe, and cut the end off. I then squashed the open end flat and brazed it closed. After that, I put the pipe in the hose and sealed it with black RTV. It hasn't leaked a drop.
If anything, take the existing banjo bolts to a good hardware shop and they will be able to help you out. Make sure you use a crush washer and that the bolt has no shoulder.
The only thing I'd be worried about is the flare sealing. The flare fitting for the water return line is meant to have a line with a 45* inverted flare fitting installed.
Personally, what I'm going to do is just put JB-weld on the stock oil feed banjo bolt and make it a permanent addition to the head. Then I might take the stock water return line, crush it and weld it shut, and use it for a plug on the water return fitting.
