bogs between shifts
kelvinb
726
3
May 7, 2004
Lincoln, Nebraska
Basically whats happening is between shifts at high rpms, once i get back into the gas it bogs. It feels as if the car is dieing, and after a second or two, it will be back to normal and go. Unfortunately i dont have my logger hooked up to see whats going on, but im assuming its running fairly rich? On 3-4 shift it sounded like a small backfire.
14b/13psi/stock ic/450s/w255/aeromotive afpr 37psi/
Engagement for my clutch is about 5in from the floor, maybe something associated with that?
Unfortunately it was dark out, so i didnt get to see if it was REAL rich.
the car is driving excellent, launching with this new clutch is awesome. the pedal feels real strong and engagement disengagement is right where i want it.
Might be a stupid question here but...are you venting to the atmosphere? If you are, thats the problem but it may be way more complicated than that.
  • Wanted 6 bolt NT water pipe
    • chrisman287
