Bogging out around 4500Rpm Log inside
91tsitalon55
May 21, 2011
Seattle, Washington
Hey everyone here is a log of a 2nd gear pull and I cant figure out why im bogging so bad around 4500 rpm. Well anyways just seeing what kinda advice I can get. Thanks
is this suppose to be a WOT pull? bc i dont see your throttle going to 100%
is its configured?
also what injector and what fuel are you using?
b/c on your log its showing 815cc and on e85 but on your profile you have 560cc?
Where does it say that? Im running 560cc on pump
Did you get this used?
If so then I would recomend you zero out everything.
Read up on ecmlink forums as well as watch all the video tutorial.
I just started out with mine a week ago and the videos helped out a lot.
But make sure you have no issues(boost or vacuum leak, timing is setup correctly, fuel pressure is set etc)
And to answer it's on your fuel tab,
You need to set your fuel setting before anything. Set your idle then cruise then wot.
Sound to me like you haven't done the idle yet. Do that first.
