Blue top injectors
speedracer91
281
Jul 10, 2004
Rockford, Michigan
i just got a new 6-bolt cuz well i blew up my last one and this one has blue topped injectors i was wondering if anyone knew anything about them? what cc are they? thank you :thumb:
I have both an auto and a manual. My manual has the 450's(bluetops) and the manual has 390's and they are black.
DSMSpyder99 said:
no all manual 4G63 came with 450cc
I think PhatTSI meant to say his AUTO came with black tops (390cc's)
Anyway, to answer your question, the extra motor you are going to put in was obviously from a manual DSM, so you will have the 14B turbo instead of the 13G you had on the auto. I am not positive, but I think auto and manual ecu's aren't interchangeable. If not, you will need an ecu out of a manual car. Otherwise you can put your 13G setup (exhaust mani, coolant/oil lines) along with your black tops on the six bolt, but I wouldn't recommend it.
My bad i meant my auto has blacktop 390's. I tried switching out my manual and auto ecus both eprom and my car would not run with the auto ecu in it.
