Blown Turbo? Head Gasket?
JuiceGsTurbo024
167
Mar 3, 2003
209, California
Alrite i have done some research and i found a few answers? but i wanted to post my issues to see which one is the problem? well if you can help that be sweet well here are the symptoms? When i turn on the car everything is fine? turns normal? so i drive off? and i see a little bit of smoke? and then when i hit about 2k 3K hella smoke comes outs? the smoke looks white? so i take of my intake and i see this nasty a$$ oil! its like silver? like if it had some metal pieces? so i check my oil in the engine but the level is fine and the oil is clean and i check my rad water and thats clean i take of the oil cap? and look for any white film? under the cap? to see if water is getting in to my head? but nothing? so I Pop my hood? while my car is on? and i rev it from under the hood? and i see a hella smoke! comingn from the exasut? and hella smoke from every where in my engine bay? So i think its a bad turbo? becuase i still can drive my car? it does not over heaat? this started in The bay area? and iw as able to dive all the way to modesto about a hour drive? and i did not over heat? or anything? and if it was the head gasket? wouldn't my car overheat? and drive $hitty? well if you can help thanks i am sorry for posting again just wanted some answer from my fellow dsmers! awww man sometimes i want to give up on my CAR!!!!! but damn it i love that TURBO!!!!!!!!!!!!!! :dsm: :cry: thanks for your HELP! latez
its ur turbo. take ur intake off and check for shaft play..i bet u have a lot. and yes, if it were a headgasket, u would most likely over heat.
If you have metal shavings in your intake you need to inspect your turbo. Specifically the compressor side.
Modesto, huh? I live about 20 mins south :thumb:
Whats up well thanks for the help! i am looking in to getting a 16B from a friend of mine? hopefully its not blown? everything else is hahah! its all crashed! he got it for his car but the swap was to much! thats tight your from atwater i use to stay in livingston? you come out to modesto? well thanks for the help everything keep you updated!
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
