Blown Headgasket Confirmation
Clinical
1,398
11
Nov 15, 2009
Cedar Falls, Iowa
So my car has had an issue pushing coolant but never overheating, and I've been pretty sure it was the headgasket.
Then after a tuning pull the other day it started heating up so I let it cool, then took it home.
It keeps idling funny, so today I was checking it over again, I see coolant pissing out the back of the motor. It looks like right around where the coil pack sits, except a bit lower.
I'm assuming I just finished off my headgasket? I can't think of anything else tiny in that location that would be ferrying coolant
Well I'm not surprised. Running 2-3 years at 25psi on E85 although conservative timing, all on a OEM headgasket will take its toll!
MLS here I come!
Ultimately, it could mean many different things. In this application, I would say yes. If the compression check failed, the likely cause would be the HG being blown. It could also be things such as bad piston rings, bent valves, or leaking valve stem seals. Just depends on the situation.
