Blown head gasket? this is bs
cmptrphreak
194
Jan 7, 2005
Chicago, Illinois
Alright, So my car is loosing coolant not leaking or anything just dissapearing I think it might be the headgasket. The car overheated like 4 times on the highway but I shut it off before the temp gauge went all the way. Could the car even overheating once blow the gasket just a little bit. Maybe the o-rings caused interference with the cometic high pressure metal headgasket. Also does anybody in the southside chicago area know where I can get the rad fluid tested for hydrocarbons?
did you check your turbo. there is coolant running to that. also do you have a lot of white smoke coming from your exhaust? I currently live in west chicago, i go to uti there. um we can test it here, but goodluck trying to get your car in. call around and see what you can find. try midas maybe?
