FullOutPwr
- 0
- Dec 25, 2002
Willard,
Missouri
Ive searched, and havent found the wire colors for the blower motor. Person i bought the car from gutted the interior and moved a lot of stuff around, blower motor was SUPPOSED to still work, sure doesnt... Turn the fan switch on, nothing happens, no clicks like a lot of you get. What are the wire colors that power the blower motor? Im going to try 12v to it, see if the motor took a dump. THANKS!
) and see if it works. You then know you only have a ground problem. The ground runs through the resistor pack (except on high) and then to the switch (which provides the final path to ground). If Don't have Hi then it's not a resistor problem, but a feed, blower, switch or ground problem.
