Blowby issues
nicknorth11
663
7
Feb 9, 2005
Grand Blanc, Michigan
I bought my car with a rebuilt motor. It had .20 over pistons. I stroked it and ordered .40 over pistons from wiseco, but they sent me .20 pistons. My machinist said they would be fine. I broke the car in exactly like I was told to do by my machinist and the motor now has about 20k miles on it. The car has excessive blowby, especially at higher boost levels. I did a compression test and one of the cylinders is about 10-15 psi lower than the rest, and the other three fluctuate between 5-10 psi.
Do you guys think I should just get new rings, or do you think my machinist made a mistake using .20 over pistons again?
If that were the case, would I need to go with bigger pistons (.40 over) to fix the blowby? If I boost 21 psi, I get tons of oil shooting out of my dipstick. I have a catch-can with a breather coming off of the valve cover and still can't keep the dipstick from spewing oil.
